12" w7 sub problem
To be honest...I don't even know what half the knobs on the back of the amp are for?? Maybe i've messed with one of them on accident?? not sure if that would cause it ( if you couldn't tell i really don't know much about it haha)
What kind of car do you have? A 1000/1 can draw a lot of current, and I say that chances are, your car's voltage is dropping too low.
You know, i've had problems with my car battery actually. I've had to jump it a couple times. I have it in a 2002 Escalade. Anytime i leave the car stereo on without turning the car all the way over it almost always won't start back up..
Yeah, looks like a weak electrical system is your culprit. What size wire are you using, and how old is the battery? You might want to look into a new, beefier battery, and doing the Big 3 (If you're not sure what that is, search for it) Make sure you're running at least 4awg power and ground wire, and make sure your ground goes directly to bare, shiny metal.
theres your problem.......maybe new battery under hood or an additional battery and big 3 would definately help
Frame if possible:D
Not sure on the wiring...i just recently got a new battery installed...but i'm pretty sure it wasn't anything beefy...just got it serviced at a local station.
that drains the batt when the cars off //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Stephenc44
Stephenc44
Kansas
Stephenc44
