Featured Good day guys i need a little help, i have a 12" American bass 1200 rms 2400 watts max n a boss 12" 1600 watts max , wats the w×h×l of the box?
Haffar Isaacs
Need help building a box for 2 12" subs, both sub i wanna put in d same box,. 1 American bass 1200 rms n a boss 1600 watts , can u give me the measurements of gow i should do this
Build Photo
  1. Okay
For the American Bass these are the parameters for a sealed box.
I do not know what Boss sub you have.
If you put them in one box, go sealed and use a divider.
This the box i have them in but like its not the right build am not sure, h13" × w32" × d25"
A sealed box is up higher and this looks really close for ported
Ok, i have a single 12" box i used to play it in dimensions are , w31" h13.5" d17.5" n the port is long inside its 3" wide port
For what?
Those subs are pretty different from each other, I would not run them together, and if you do, two separate chambers / boxes as mentioned. Two cars means don’t run them together in one box in one car.
That American Bass sub is light years better than that Boss sub. Run the American Bass in a good ported box with a real 1500wrms amp and it will bump.
Ok understand, can u give the a good box size at 32 hz and length of what to cut? Am kinda new to this
Haffar Isaacs
Haffar Isaacs
The Caribbean
Haffar Isaacs
slater
    Oct 4, 2025
    Oct 4, 2025
