Haffar Isaacs
Need help building a box for 2 12" subs, both sub i wanna put in d same box,. 1 American bass 1200 rms n a boss 1600 watts , can u give me the measurements of gow i should do this
- Build Photo
- Okay
For the American Bass these are the parameters for a sealed box., can u give me the measurements of gow i should do this
I do not know what Boss sub you have.
If you put them in one box, go sealed and use a divider.
This the box i have them in but like its not the right build am not sure, h13" × w32" × d25"For the American Bass these are the parameters for a sealed box.
You'd be better off just running the American bass in a good box. The boss sub will knee cap how much power you can runThis the box i have them in but like its not the right build am not sure, h13" × w32" × d25"
The American is 1200 rms 2400 watts the boss is 1600 wattsYou'd be better off just running the American bass in a good box. The boss sub will knee cap how much power you can run
The boss is closer to 200-400 watts rms...maybe lessThe American is 1200 rms 2400 watts the boss is 1600 watts
Ok so can u give me some dimensions if i hv to use the American bass only in a single box?The boss is closer to 200-400 watts rms...maybe less
Ok, i have a single 12" box i used to play it in dimensions are , w31" h13.5" d17.5" n the port is long inside its 3" wide portA sealed box is up higher and this looks really close for ported
Subwoofer box American Bass 12 inch elite 1244
12 inch subwoofer box design American Bass 12 inch elite 1244, ported box plan, 3D model. Net internal volume 2.50 cubic feet, port area 30.00 square inches, tuning frequency 32.5 Hz. Subwoofer box calculator onlinesubbox.pro
Put it in there and see how it sounds...it might be or might notOk, i have a single 12" box i used to play it in dimensions are , w31" h13.5" d17.5" n the port is long inside its 3" wide port
Its buffing alotPut it in there and see how it sounds...it might be or might not![]()
