Setting dials on Amp alongside LCi2
zoltman1991
Thanks again for everyone's help!
I have searched hours but cannot find exactly what I'm looking for.
-I have found videos of how to set gain on amp.
-I have found videos of how to set settings on LCi2
But I have no found how to do both in conjunction with each other.
Research suggests I turn the bass/main dials on the LC2i until 'maximized' light turns on.
I also set amp by matching the voltage sqrt(1200w x 2ohm) = appx 48.
But when I rotate dials on LC2i, the voltage drops to about 30 before I hit the maximized light.
Do I leave it at this? Or do I then increased gain on amp to hit my 48.
I guess another question is, which do I dial in first? Amp or LC2i?
Start at the top and work downstream. HU, LCi, Amp. The idea is to get as much out of each without clipping the signal. In some cases, if it is plenty loud prior to reaching that point, leave it be. I have 200 waits x 2 channels left over for my rear tweeters, the gains on that channel are set very low at the amp level. I set the HU very conservatively so that if turned all the way up, not clipping.
The LCi is an active LOC, it will give your amp enough to go on so make sure that the signal it gets is clean and adjust away!
Ar about the 4:20 minute mark, this guy who uses and is sponsored by AC touches on the settings.
So to confirm:
Gain on amp all the way down.
Turn LC2i BOTH main/bass knobs until I hit light, then back off a bit. (edit - it seems I only need to turn one knob, which is the bass knob. Is this correct)
THEN I set gain on amp to reach my desired 44v level??
Scratching that. My amp will be JL JD1000.1, which has speaker level input. Should I just dump the LC2i all together and avoid the headache? Seems unnecessary if the JD1000.1 has speaker level inputs. I would just turn the high voltage input switch on.
So to confirm:
That depends. Are you confident that the HU is full range, do you need the Acubass? That LCi2 (non-pro version) has a fixed HP (subor infrasonce) filter at 33hz. If you're planning to tune the subat below 35hz, then I would not use the non--pro LCi2. The pro versions fixed filter is fixed at 24 or 22 hz?
Why all the money on that JL? It's not one of their better models, doesn;t have a subsonic filter so depending on your subs tuning, the AC unit would be beneficial.
Korean designed amp options that have better controls and higher output, just to name a few are:
Brand new at $330
Refurbished at $200
They both have subsonic filters but would be best used with the LCI2 pro model. That refurb unit is sold by a VERY reputable dealer and along with the LCi2 pro would be a better option.
If you already have the amp, then you can use it or lose it, sub box tune dependant.
Brand new at $330
Refurbished at $200
Eh already ordered the amp.
Ok wait back to the setting the dials. I listened for any drop off, couldn't identify any in my listening range (up to 75%). But IF I keep the LC2i, was I correct earlier?
4.4v level, sounds about right.
You mentioned subsonic filter.
I see the LC2i has a frequency response starting at 33hz. Would this be effectively setting the subsonic filter and not letting anything below 33hz reach my subs?
If not, I'm seeing there are RCA active filters. What is your experience with these?
The LC2i has an internal 33 hz fixed subsonic filter, no need for anything else if you use that LOC. The LC2i Pro is around 22-24hz.
Snag this one while you can!
Might want to ask if all the hardware comes with, otherwise, two of these may be needed:
Perfect! Already have the LC2i. Was in my last system as well.
Is the 33hz good enough? My biggest thing is delivering clean sound while maintaining speaker safety. Safety is first for me!
zoltman1991
zoltman1991
houston
