F150 4 8’s installed
EricF
I’m really glad I went with the 4 8’s over my previous 2 10” set ups in my other trucks. Everything came together pretty well, the only issue which is being corrected is the shop used the wrong line output converter. The LCI1 doesn’t compensate for the OEM roll off. Once you get past half volume the subs start to dial themselves back. Aside from that, I can’t wait to really see what they’ll do! They’re very punchy and for 8’s they can still get decently low. I can move the windshield wipers pretty easy when it’s turned up.
Factory B&O system
Custom seat lift and sealed box
4 8” Ground zero subwoofers
3000.1 Sound design amp
0 gauge wiring
Factory electrical for now (I plan to upgrade the mids and highs eventually)
Factory B&O system
0 gauge wiring
Looks nice and sounds good! I'm running 4 - 8's in my truck as well. Good job man! Welcome to the little sub club!
Thanks haha, I’d be curious to see what 6 6.5” subs sound like as well.
What about 32 - 6-½'s?
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
Thanks so much guys. Talked to crutchfield support with the same question and although they likely don't know everything, and sometimes, salesmen...
They really are. Fit to perfection! Sounds Good Stereo are the best.
EricF
EricF
Alberta, Canada
Bobbytwonames
SlugButter
    May 4, 2024
slater
    May 2, 2024
