Is it possible
To be able to wire a sub amp to the speaker inputs without damaging anything by keeping the battery plugged in?
Or would it end up ruining something?
It is possible. But it is easy to slip up. I once messed up a radio"s speaker outputs when splicing in a sub amp. As a reward, I had to use the RCAs and add a 4 channel. A sacrifice to the laziness deity.
Yeah always do that stuff with the battery positive disconnected when working on anything car audio related. If you have everything installed then you pull the main fuse out so there is no power going to the amplifier or speakers then but the radio keeps all its settings.
When 1st installing I do that but after that I just pull the main fuse at the battery for the amplifiers that way I don't lose anything at the radio. And if I am doing stuff with the radio I just pull the harness out that attaches to the oem harness. But just working an adding speakers/amplifiers eh the main battery fuse for the amplifier works and takes 2 seconds and you save settings that way.
411
Hmm.. No Bueno. Id prob be looking at another set of subs to be honest. Like some American Bass DX series. Great subs for the $. Maybe even look...
652
Thanks for this! Yes, there are 6.5 door speakers, front and back. I've heard them referred to as woofers but I'm sure their frequencies included...
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
MyNameIsHere
MyNameIsHere
USA
Slo_Ride
    Apr 28, 2024
    Apr 28, 2024
