Help Me Choose 8s
I think I'm gonna go with SA8 or F8L. Only thing the F8L has on the Sa8 is a bigger voice coil. How are the F8L rated? Do I give them 650rms or can they take a bit more like 800rms
Would three SA8 in 3ft3 tuned to 33 hertz on 1600rms work?
Yeah that would. Those sa's will take a little bigger box if need to make up for any power lack. If I had 3 sa's, I'd probably get 3 d2, wire them up at 1.33 ohms on to something like a 2200 w mono block.
Those sa-8's are very well designed and will take some power. We just need to make sure we can fit the port for those 8's. Smaller net cubic footage boxes use bigger ports. So like an 18 in 6 cubes will need less port than an 8 in .75 cubes, very vaguely speaking. The smaller the box is in net cubic footage, usually the bigger the port has to be. There's ratios there. You can get away with incredibly small ports in boxes that are like 10 cubes+, even for very high powered woofers. These high powered 8's are some of the most likely setups to get port noise. The OG sa-8's, I had people getting port noise with 18 in^2/cube of port area. I had to do 20 in^2/cube of port area with the OG sa-8's in some vehicles just simply to avoid port noise. That's a HUGE port, and it can take up a lot of space very quickly. So please keep that in mind with the space that you have and where the box is going, because we could run out of space, especially if we're doing it behind the rear seats and need to fire the port towards the side or something like that.
My first sa-8 box design from 2011:
28645
2012:
28646
2013:
28647
2014:
28648
Was sick in 2015 so 2016:
28649
I have more but some I can't show due to business agreements. I have 37 sa-8 designs saved on my computer.
I worked for/with a Sundown dealer. I've designed, built and then installed many Sundown sub boxes myself, in real life. Please trust me on that.
Every box design file I have saved, 986. Doesn't include everything I did in high school and the dozens of boxes I did on paper in the office of a shop and built them the same day lol:
28652
What's the difference between the digital designs hidef 2008c and the digital designs power tuned 2508f series. I know the redline is made in China right.
This would be a decent amplifier to run on what you have. I would spend a little more and get the 460.4 if you can swing the extra funds. Ive...
Sub should be in the cargo area for best results. I'm skeptical about those unknown brand Chinese head units myself and would stick to known...
I am upgrading standard door & dash speakers in a VW T5 camper (2005) using a plug and play upgrade bundle, continuing with the two-way setup...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
292
Icecube91
Icecube91
Vancouver, BC
Icecube91
DEW123
    May 7, 2024
DEW123
    May 7, 2024
