There should be a removable filter on the bottom of the case already... or is it just for the PSU?I'm going to put in some fan filters on those bottom fans.
Feel around on the back under the PSU... nothing?My case came with 2x 3-stack 3.5 hard drive cases where those bottom fans are, no filters. I modified that part, only supposed to be 2 120's down there anyways. But I did the 2 140's and drilled the holes out, so that's what I'm putting the filters on.
40c at idle is fine. Don't put the aio in manual, let it run in auto and make sure the fans for the aio are plugged into the cpu fan slot so they can ramp up when the cpu gets hot. Pull your water block and redo the thermal paste. Not because it's bad, but because with the ryzen installs I have done for some reason the pre-applied thermal paste on water coolers does not cover the entire cpu. I personally run thermal grizzly kryo. Used to run arctic silver 5. Either will be fine. My ryzen idles around 40, and they holds that 40 even when pushing it. Your motherboard is designed to monitor cpu Temps and ramp the fans up on the aio when needed.
Yeah I have a filter there, that's not what I mean. I know it's ugly lol. Not done, just had to tape it with what I had atm, because the bottom isn't flat, there's ridges, so the sides weren't sealed. This is on the bottom.
