You're opinions matter
I wanted to add this after rereading everyone's suggestions here's my current box not sure what's it tuned to as I bought it with the wdx's from someone. seems like a solid box?? What I've gathered is basically invest in taramp or equivalent which will get me to where I'm trying to go, along with electrical upgrade big 3 ect ect.. Also I'm currently running a pioneer 4300bt and a sound stream eq. Forgot to mention that.
Im curious how much that taramp will make a difference for only two hundred bucks I'll probably buy it and see how big of a difference it makes.
Two suggestions. Get a Taramps Bass 5K first. If you aren't happy then get 2-Fi Q series 12's.
I'm curious how much that taramp will make a difference for only two hundred bucks I'll probably buy it and see how big of a difference it makes.
Taramps smart 3 I'd try if your being cheap for sure.
I was surprised by the smart 3 power myself, its going to want current tho so be warned... its a little powerhouse.
All the talk of big 3 is all well and good with an alternator and secondary battery is going to be needed etc.
I'm positive you'll see big gains over that PPI... it'll be a HUGE difference. That Ppi "5K" is such a joke
Thanks for the input guys And I'm gonna take the advise with the tramp here in the next month along work on the electrical starting with big 3 I've also got a brand new duragm-14 laying around would I benefit any by using this temporarily while I wait and save up for better battery?
Specifications
  • Item Number: CYL10012
  • Brand: Duracell Ultra
  • Voltage: 12
  • Format: 14-BS
  • Lead Acid Type: Starting
  • Capacity: 12AH
  • Cold Cranking Amps: 220
    WARNING: Cancer and Reproductive Harm - www.P65Warnings.ca.gov
  • Battery Type: Factory Activated
  • Chemistry: Lead Acid
  • Comes With: Two 17mm Adapters
  • Lead Acid Design: AGM
  • Made in the USA: True
  • Product Category: Powersports
  • Product Sub Category: Domestic AGM
  • Warranty: 24 Month Free Replacement
  • Weight: 11.5 lbs
  • Length: 5.87 in
  • Width: 3.38 in
  • Height: 5.75 in
That little motorcycle battery MIGHT help... it looks like 12ah so don't expect much. Once you get your Smart3 it will be only a drag on your system imo unless you have a hi-output alt /w/ sufficient wire. Even then I'd recommend ditching it altogether and getting a pair of 65ah+ agm along with an upgraded alt (250a+)... That Smart3 IS surprising and will be a HUGE increase in power over the Ppi "SPL 5K"...:ROFLMAO:
Just research the filters on the Smart3 when setting it up... its basic, but seems to confound some people
Bryan3710
Bryan3710
California
shredder2
