Building a new box 3 12" sundown audio sa's
Bldnasty
I just bought a 3rd 12" sa sundown to add to my system. I bought a box on line for 3 12's. I should of known better but did anyway and yep it *****. the whole box is just garbage. Its like 3 separate boxes and just carpeted together. So I am just gonna take my time and build my own just not sure what i want to build. prob. just a ported box. Its hard to find any dimension for 3 hole box. If anyone could help me design it would be greatly appreciated. Thanks Fellow Bass head.
The list:
Vehicle : is a Nissan nv200
Location in the vehicle: rear of van
Space available (Length x Width x Height): 4' x 4' x 14"
Subwoofer make and model: sundown SA
Subwoofer Size:12"
Number of Subwoofers: 3
Type of Port (Kerfed, Slot, Aero, etc.): open
What type of music do you like?: hip hop, bass music
Is your goal SPL or Everyday Music?:both
Tuning Freq (Hz): 35
amp is a american bass 2500hd
Ebay look uo sundownaudio ported 2
5 cu ft box ull find 1 for 289$ well worth it!!
That amp isn't big enough for three of them. Look at a Taramps MD5k. And make sure that your electrical is in order. Minimum 2 batteries, 1/0 big three, and a H/O alternator. The amp will give you the headroom you need, so, you don't have to run the amp gain so high.
Don’t buy a box off eBay. Have it built. And with 3 subwoofers, which im guess they are dual 4 ohm subwoofers, would wire to about 3 ohms in series or about .5ohm in parallel. So either you will be seeing less power by adding a subwoofer or you will damage that amp in due time. Your gonna have to get another subwoofer and amp (my choice) or ditch that new subwoofer and go with 2 subwoofers and the amp you have or just get another amp if you want to run 3 subwoofers. And them subwoofers want about 1500 rms a piece.
20772
20773
The list:
Subwoofer Size:12"
Are theyb12s 15s? N what kind ofnsd audio r they aka rms forneach sub?
The crossover is just a pair of 3way, 300watt crossovers I picked up from from amazon. the subs I have are 8" Kicker FreeAir f8a I am looking...
826
Build currently on hold, waiting on a custom voice coil. The former isnt tall enough for the new setup. On the plus side the motor has 3.25" of...
30
4K
Bldnasty
Bldnasty
New Orleans
Slo_Ride
    May 18, 2024
    May 16, 2024
