What subs hit harder then jlw3 for under $100?
Why 600rms not good is the sub is 1000?
nope, box rise will only get you 100-300 watts of real world power. Always have way more power on tap. 1000 rms sub doesnt mean louder. It just means you need a fk ton more power just to get it louder. better subs dont do anything unless you have power to back it up.
Also you have a 2 volt head unit. Thats limiting your output for sure, will see a huge jump when you swap to a quality head unit.
Also set your volume high, like really high or else you wont get the full 2 volts out of that head unit. Like legit trust me on this, everyone that doubts this gets blown away when they actually upgrade their head unit. I got countless threads like yours with everyone underestimating the power of a strong signal.
What head unit you recommend?
this head unit is solid since you already have mechless (no cd).
That signal (hu) and proper box are what I would prioritize. The amp you have is a budget performer. Don’t blow your cash on the amp first.
When i turn “bass eng” all the way to 6 and “subwoofer output” all the way to 15 it bumps hard on low volume but im not sure if that unsafe for subs. And how loud i can play with that on without blowing
Most likely your ground. I've seen that happen, the sub looks like it's playing a 5 Hz note. If one piece of equipment doesn't have a good ground...
709
304
If they had an orange basket I would have to buy them.... Hmmmm Sell my 4 Xs and get 6 of those and do no-wall again with one more 4500..... :unsure:
403
672
Retrofuture30
Retrofuture30
Louisiana
SlugButter
    Apr 28, 2024
    Apr 28, 2024
