The amp good....if it said rockford youll probably be all over itBruh, fuck off with this garbage.
Whatever bro. At least try harder. Weak ***.The amp good....if it said rockford youll probably be all over it
Wowh thereWhatever bro. At least try harder. Weak ***.
LMAO!!!!
I don't think you know what loud is. You have people doing mid to high 150's and even 160's telling you the reality of situation, it's not their fault you refuse to listen.The amp good....if it said rockford youll probably be all over it
whats your signal line looking like? Head unit? LOC? because thats the main culprit most of the times if you are using a stock head unit or a low end head unit with shitty DACs and preout specs.I think ill just keep my sub thanks everyone. Im not looking to find out specs and take it to a shop to get custom box. Just something easy and simple that louder.
Ill rock with this jl and get a big box like others said, till ill try other brands. Appropriate help
4 gage wirewhats your signal line looking like? Head unit? LOC? because thats the main culprit most of the times if you are using a stock head unit or a low end head unit with shitty DACs and preout specs.
I dont need it that loud just loud enough. Is a l7 preloaded better?If you’re not willing to either build or pay to build a custom enclosure, you will never get loud loud. You’ll pay twice as much for amps and subs to get the same results you would on half the power. Those w3s are very nice subs, and in the correct box, will get loud and low. With your current system setup, a designed box built for that sub is the only way to get louder.
