First box build log
Omg... this thread
Op... sounds like your almost done now and then this...
Not butt hurt. Just have to start over.
Made a hole that was tuuurible
18309
Maybe you can save that, slap another piece over the entire front then cut out the mounting holes better and the port.
Id at least try.
Or rebuild... Practice makes perfect.
Id at least try.
You're right that'll work.
Glad I got my feet wet with cheaper mdf board. Almost bought birch but thought better of it
Just use a scrap piece with 2 screws a radius apart, run one screw in a bit where you marked center and use the other to scribe a circle. Afterwards just darken the scribe mark with a pencil so you can see it easily, drill a hole inside the marked circle big enough for the blade and then cut carefully and slowly.
Ghetto protractor...
Just use a scrap piece with 2 screws a radius apart, run one screw in a bit and use the other to scribe a circle. Afterwards just darken the scribe mark with a pencil so you can see it easily, drill a hole inside the circle near the mark big enough for the blade and then cut carefully and slowly.
That second hole was done using a version of the ghetto protractor lol
Just went too small
You need to think things through and use your brain. You don't sound retarded, so when you catch yourself doing stupid shit take a step back and think of a better way to do it. Seriously, join a tampa car audio group or something and ask someone to help you.
danielbea122
CarAudio.com Exclusive
danielbea122
Tampa
fithwheel
