First box build log
Omg... this thread
Op... sounds like your almost done now and then this...
Not butt hurt. Just have to start over.
Made a hole that was tuuurible
18309
Maybe you can save that, slap another piece over the entire front then cut out the mounting holes better and the port.
Id at least try.
Or rebuild... Practice makes perfect.
Id at least try.
You're right that'll work.
Glad I got my feet wet with cheaper mdf board. Almost bought birch but thought better of it
Just use a scrap piece with 2 screws a radius apart, run one screw in a bit where you marked center and use the other to scribe a circle. Afterwards just darken the scribe mark with a pencil so you can see it easily, drill a hole inside the marked circle big enough for the blade and then cut carefully and slowly.
Ghetto protractor...
Just use a scrap piece with 2 screws a radius apart, run one screw in a bit and use the other to scribe a circle. Afterwards just darken the scribe mark with a pencil so you can see it easily, drill a hole inside the circle near the mark big enough for the blade and then cut carefully and slowly.
That second hole was done using a version of the ghetto protractor lol
Just went too small
You need to think things through and use your brain. You don't sound retarded, so when you catch yourself doing stupid **** take a step back and think of a better way to do it. Seriously, join a tampa car audio group or something and ask someone to help you.
917
The tricky bit is that they're soft and floppy and they may be stretched a tad to go over the frames. I've used them in the past and come out...
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Thanks everyone for the feedback. I got scared of the 4th being to much for a newbie but did end up building a box to 2.1 Cubic Foot tuned to...
Love this sub, hate AB's site, short on info for sure. American Bass XR-10D2 box recomend: If you want to tune a 2.75 Cu Ft box (for two of these...
danielbea122
CarAudio.com Exclusive
danielbea122
Tampa
fithwheel
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
