Modern DSP wired controller upgrade idea
It'll be quite awhile before it needs any firmware updates, the dsp GUI is soo smooth on every phone i've tried it on. Fast stable connections all around no bugs.
Ive got multiple Windows tablets to use mine with. But itll be a set it and forget it thing for me.
I was more looking if they could add a feature or if possible or provide feature support down the road. Like having usb storage support.  I like Bluetooth when it works right, but not everyone owns an 800 dollar streaming device with good Bluetooth.
I'll correct myself here.  The aptX codec feature is actually available on a ton of android phones now.  How that particular phone utilized that feature to stream over Bluetooth is another story though.Also whether they support aptX HD will tell you more about that devices quality and capability. With that said some older phones (we are not talking old here, except by techy definitions) 2-3 years old support aptx and some aptx HD (oneplus 5t but much more expensive used), are pretty cheap if you want to buy one to use just as a player.
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
927
Power is a lot cheaper these days and amps for the most part are more efficient...especially the multi channel class d amps...I can't tell the...
15
Just the amplifiers use batteries to power it up. The HU are powered up by the car battery supplying 12 volts. The wiring harness...
Hey kids. I see modern head units have 'pandora connectivity' an other stuff. How do these work? Are they, say, a pandora app on the device...
Jeffdachef
Gunz That Turn on Nunz
Jeffdachef
South Coast Metro, CA
nate0
    May 23, 2024
    May 22, 2024
