DS18? Newbie alert
OP, you can also do this
https://store.soundsolutionsaudio.com/products/sound-qubed-hds212-12-inch-subwoofer.html for $110
and that soundqubed S1 850 watt mono for $100.
Build your box and boom, done. Less than 300 invested and it'll hit for sure
( there ya go @denim )
This is a great suggestion, I think I'll go ahead and get 2 of the Soundqubed 12 inchers, would the SoundQubed 1200D amp work?
This one? https://store.soundsolutionsaudio.com/products/soundqubed-q1-1200-2-amplifier.html
or maybe this? https://www.amazon.com/SoundQubed-S1-1250/dp/B07B4MDN2Y/ref=sr_1_11?ie=UTF8&qid=1544769765&sr=8-11&keywords=soundqubed+amplifier
that 1250 is a solid amp too, just make sure youre running proper electrical to it, build a ported box spec'd out by @shredder2 and the result will shock you
edit: you dont have to run a sundown. there are many brands out there that are far superior to DS18, but sundown is an obvious choice. The all in ones are ok if you want no fuss and not much bass. Also, most folks arent out there to blow their trunk lids off, but that sundown will give you some great response and the ability to destroy when that one tune comes on that you just want to crank the f**k out of. FU audio is a good cheap alternative. Massive audio makes a great driver for the price too.
SSA is also an obvious choice. ;)
depends on how many woofers youre getting and what amp. if its one woofer and a 1 ohm stable amp (most new amps are 1 ohm stable when theyre monoblocks) 1 woofer 1 amp get 2 dual 2 ohm. 2 woofers 1 amp, get dual 4 on each sub
I think I've made my final decision - Goin with 2 x SoundQubed HDS212 12 Inch - with the Soundqubed S1-1250 Amplifier - Just need to find the right gauge wires, and see if I want a shop to build me a box or somehow do it myself!! All input is appreciated, many thanks to all of you! Once all is said and done I'll post pictures here
good choices. SQ makes decent subs and their amps are hard to beat for bang for your buck. just get the box built to spec and built well (make sure to use corner 45s) and youll be bangin
114
9K
I'm hoping 🤣 I still gotta decide on drivers up front but I might just the cdt components I got now and add a unity mid 🤔
42
6K
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
807
That blue wire with the "remote control" sticker on it: It's NOT a remote control wire. Its a remote... control wire. Its a switch that...
Ethan Carlson
Ethan Carlson
denim
    May 12, 2024
    May 11, 2024
