T&T Audio Up and comming subwoofer company
Bomtillington
Hi everyone i am trying to start my own audio company with a buddy of mine and ive sourced some good woofers and im trying to get a feel for everyones intrest in them. they are rated at 1500 but im sure they can take 2k they only come in 12s.
Thiel-small Parameters:
1), Sensitivity (1M/1W) SPL 85.5dB
2), Electrical Q Value Qes 0.51
3), Mechanical Q Value Qms 2.89
4), Total Speaker Q Value Qts 0.43
5), Free Air Resorance Fs 40.2Hz
6), Equivalent Compliance VAS 18.2L
7), One-Way, Linear Excursion Xmax 22mm
8), Force Factor Bl 24.9 N/A
9), DC Resistance Re 1.8+1.8 Ohms
10), Normal Impedance Znom Dual 2 Ohm
11), Net Weight N.W.
25KGS
12), Gross Weight G.W.
28KGS
13), Package Dimension P.D.
37x37x32cm
those are the specs pics will be comming soon let me know what you think!
General Specifications:
• Die-cast Aluminum frame with black glossy coating
• Non-pressed pulp and carbon fiber cone
• Tall Foam Surround
• High-temp 4" Dual 2Ohm 4-Layers BASV/CCAR voice coil
• Multi Layer Nomex Spider
• Tinsel leads woven on Spider
• Chrome Plated heavy 8gauges push wire terminals
• High-efficiency triplicated 100Oz total 300Oz thermal magnet
• Thicker chromed Vented pole piece
• Rubber boot to magnet portection
• Rubber gasket
• Polypropylene Dust cap
aditional info!!
As the company builds i can add more amps to the list but theese will be the first two amps comming soon
Class D amplifiers :1200D, 4000D,
guts shots of the 4000d comming soon
---------- Post added at 12:47 AM ---------- Previous post was at 12:47 AM ----------
if you right click you can view them in new tab
by the looks of the coil and spider ur going for a daily sub...
---------- Post added at 12:10 PM ---------- Previous post was at 12:09 PM ----------
good luck with ur ventures //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
6
962
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
997
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
6
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
5
Bomtillington
Bomtillington
Rhode island
Bomtillington
pfft
    May 1, 2024
pfft
    May 1, 2024
Latest topics
