1999 ford escort lx speaker wiring diagram?
Are you planning on reusing the power pack? If yes cut the wires at the top red arrow only. Connect your new radio harness to the translucent one...
373
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
chris Boug
chris Boug
san francisco, ca
djarmy2004
    Apr 26, 2024
    Apr 26, 2024
