capacitor advice
g31 YT is a good one...
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
seriously ditch the cap idea. do a search. be learnt
Hmm, should I ditch the capacitor idea? Why?
read what you quoted //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Caps do almost no good in the system. What they do is basically help for a very short burst. Look into a better battery up front or a 2nd battery if you really have that much power going.
Also, Big-3 is FAR better than a cap. Search that.
X2, the Big 3 is the place to start before you add a battery or upgrade the stock one.
hmm I see... I did buy a bigger battery and that helped, but just not enough so that's why I thought a cap would be the next upgrade I need to do.
I have also heard about adding a bigger altenator, but isn't that really expensive?
If I add a second battery, how would I need to connect it to make it work? Do I need a second altenator for that?
1/2 farad vr3 capacitor will give you like an extra 200 Watts
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
Going all Knu for wiring, lugs, and fuse holders. Been using them for the last serveral vehicles and love their products. Battery terminals...
gardar
gardar
Reykjavik, Iceland
gardar
    Jun 3, 2024
