XTC Speaker Baffel Question
SethPhillips
I'sa Playa
i have a bunch of these XTC speaker baffels. there like a foam molded speaker enclosure to keep water off the back of the speakers when installed in doors's ect... my question is after i completely soundeadin my doors. ( im gunna go overkill on soundedining my doors.. 3 layers on the inner and outer panel ect) should i use a set of the baffels too when i install my type x woofer in the door? or should i just leave the back of the woofer exposed?...
thinking about useing the baffle but cutting it in half so the woofer is exposed but no water will drip/ get on the woofer...
basicly. should i use the baffles as an enclosure... or go baffel less
i have mdf speaker rings cut out that i will be useing w/ or w/out the baffels.. just to let ya know.
i am also stuck on the same course.
i have fully dreadened doors and i got a pair or aa poly mids crurrently. i use the baffle to seal the speaker.
with it it give it a more (sealed) dynamic sound and bass is good at a higher octave. without the xtc baffle it lets the speaker play lower (infinite baffle)
i just got a pair of SDX7 mids (extremis generation) and i am going 3 way active.
i plan on making the baffles into an aperiodic enclosure
http://www.icixsound.com/vb/showthread.php?t=37747
http://www.elitecaraudio.com/article.php?sid=18
search many ppl have talked about the xtc foam here.
SethPhillips
I'sa Playa
SethPhillips
Northern Utah
SethPhillips
