wut freq. should i use.
saintluey
i got the kicker L5 (the loaded box with a port that sells in circuit city) powered by a rf p8002, my question is wut freq. should i set my amp to get the best bass. i have the sub wired to one channel only cuz before i bridged it and blew the sub
also should i stay ported or go sealed?
Not really sure what u mean by the first part...
But as far as that it depends on your preference... If you want better SQ (tighter punchier bass, flatter frequecy responce) go sealed. I'm not sure what the box you have is tuned to, but generally if you want to get louder you would wanna go ported. With a ported enclosure there is a more peaky frequency response and muddier bass, but they are generally louder.
-=This thread has been edited to make me not look retarded... unfortunately people have already quoted me so my bad=- //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
im not sure about the freq
but if u switch between ported/sealed theres a diff in sound, usually ported tends 2 b louder for SPL while sealed makes it more tight sounding for SQ, but thas jus a generalization, if u build a proper ported box u can have both SQ and SPL by tuning it properly at the correct Hz rating like 28hz or 32hz
But as far as that it depends on your preference... If you want better SQ (tighter punchier bass, flatter frequecy responce) go sealed. I'm not sure what the box you have is tuned to, but generally if you want to get louder you would wanna go sealed. With a ported enclosure there is a more peaky frequency response and muddier bass.
ported is louder there would be no point to it if it wasnt....
saintluey
saintluey
Miami
NJack2AF
michigan born
    May 14, 2026
michigan born
    May 14, 2026
