Wiring help
I have two american bass XFL1544 subs. They are dual 4 ohm 1000/rms. I have one american bass VFL 150.1 (2900 watts RMS) 1 ohm stable D class mono block. Would I be ok wiring the subs to 1 ohm? Im asking because the box would only need one terminal in I wire down to 1 ohm. Thanks
I always run all wires to the outside, This way if things don't work out or you change amps you will have that flexibility to easily change your configuration to any other way you may need to without having to open it up and rewire it and probably will have to redo the entire wire job and terminals if you cannot get the exact same matching sets that you used the first time.
I just learned to always plan ahead now, wire is cheap, redoing things over never looks as good.
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
625
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
987
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
jimmy221990
United States
zinda
    May 31, 2024
    May 24, 2024
