Wiring help
I always run all wires to the outside, This way if things don't work out or you change amps you will have that flexibility to easily change your configuration to any other way you may need to without having to open it up and rewire it and probably will have to redo the entire wire job and terminals if you cannot get the exact same matching sets that you used the first time.
I just learned to always plan ahead now, wire is cheap, redoing things over never looks as good.
jimmy221990
United States
zinda
