Wiring Help PLEASE!?
87monteman
I don't know how I should wire my amp and subs.....the book that came with my Power Acoustik subs and amp has so many type-o's that I don't really trust it! I have a Power acoustik LT980/2 amp, 2 12in. Power Acoustic DVC FUBAR siries subs and a Sony X-Plode CDX-570 deck and well i've been trying to find out if and how i could bridge it in mono safely or if anyone could possibly help me PLEASE.....I'm so confused about what would be the best wiring set-up to maximize power and not run the risk of damaging my system. Also I don't understand how to fine tune my amp and am having problems with distortion. If anyone can help me I sure would appreciate it cause' i'm kinda new at this stuff!
Can you post the specs it gives in the book? Usually bridging comes from using a pre-determined + and - terminal from each channel.
post stuff like, what are your subs RMS? what is your amp's specs? For instance, what does the amp do at 4, 2, or 1 ohm? (power wise) is the amp a mono amp, or a 2channel amp that you are going to bridge? Is it a bridgeable amp? Keep the gains down on the amp until you get this figured out, distortion is damaging your speakers, so you do not want any of that. Keep them very low for now and dont crank it until we figured this out!
My amplifier is a Power AcoustiK LT980/2 Hyper Bass Series here are the specs straight from the book.
MAX Power @2 ohm 980w
RMS @2 ohm 280w x 2CH
220 x 2W @ 4ohms RMS
280 x 2W @ 2 ohms RMS
560 Watts @ Mono RMS
980 Watts Bridged MAX Power
THD @2 ohm
Signal/Noise Ratio >98db
Channel Separation >55db
Frequency Response +* 10Hz-30KHz (*plus sighn has an underline in the book)
HPF 50Hz-500Hz
LPF 30Hz-500Hz
Sub Sonic 30HZ-175HZ
Bass EQ 0db-24db
Adjustable Sensitivity Range 0.1-1V
Input Impedance - Low Level 10K Ohms
2 Ohm Stable Stereo
Tri Mode Capable
Fuse 15A x 4
the amp can handle a minimum impedance of 2 ohms.....it's two channel i don't know how to tell if it's a mono amp but there is a way of wiring it that makes it streo or mono but i can't understand the book and i have even been trying to do some homework.
My subs are Two Power Acoustik 12in. Dual Voice Coil FUBAR series and the Specs are;
SPL 91db
Magnet Size 200oz.
BASV voice coil: 2"
Power (RMS watts): 800
Power (MAX watts): 1,800
Thiele/Small Parameters
Fs 36 Hz
Vas 1.91 Cu. Ft.
Qms 5.731
Qes 0.502
Qts 0.462
X -max 10mm
well thats about all that i can find. Sorry for not answering sooner but i work strange hours and i really appreciate yall's help. At the moment i have the subs hooked up on one side (only one voice coil or one side of the speaker) and i'm taking your advice not to bump too loud right now. thanx yall and if i left anything out just lemme know and i'll happily post it . thanx a bunch and i'll be checking back soon
Can anybody help me please? i did some research and i think i have my subs hooked up right but i've posted all the information that i think is needed but i might be wrong so please help!
87monteman
87monteman
Mayetta, KS.
87monteman
