Some one help! PLEASEEE
Jeff06
I just got done hooking up my new system in my GMC 2500 year 1997 and when i go to play a CD the subs wont work... the amp just shuts off... but when i listen to the raido the subs and the amp work fine... any help fellas? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
and or you wired the subs wrong!? But yeah I'm guessin' that sounds like you didn't put your lead through your car to the amp. But if you didn't do that it would always be on?
THe attenna lead only sends voltage through the wire when the radio is on, hence why his system works when the headunit is playing the radio and not the cd's. Its a common mistake.
Wired the subs wrong?... No that could not be a cause of this.
It is DEFFINITLY the REM lead, swap the wires and you will be fine.
Did you get your head unit new or used? Either way - was the wiring harness for the deck damaged in some way? If not - it should have two separate blue leads; one with a white stripe and one without
The former is meant for amp activation and the latter for power antenna activation. Some head units only send current to the antenna lead when in tuner mode but the amplifier lead will have current at all times the unit is turned on.
Jeff06
Jeff06
Fort Worth TEXAS
johnecon2001
