Wiring help please! 2 same amps, 2 same woofers
  • 2
DrewB
Hello all, I now already have 2 2ohm power acoustik mofo 15s and 2 audiopipe 1500.1 d amps. Currently, I have 1 sub and 1 amp wired to 1ohm in a box I made with some help from posts on this forum (thank you all!) and WinISD that works well for me. However, I'd like to add the second woofer and amp while I remake a box to fit them both.
I want to use what I have (got a good deal on the lot) and I want to keep everything at 1ohm and in 1 box. I know I can't do this with 2 2ohm subs, which is where I need either some confirmation what I'm planning is going to work or some new direction lol... So...
A) Is it okay if I wire 1 power wire fused from the battery to a 3 way distribution block, to each amp... ground each amp individually (I'd like to avoid purchasing another distribution block to make a single ground, but I can if safety is an issue)... hook up 1 sub to 1 amp at 1ohm and do the same with the other... put a jumper between the remote wires so both amps turn on... put the RCA from the HU into one amp and use a single RCA to bridge/strap(?) the signal to the second amp to avoid a headache of running 2 sets of RCAs? If this won't work, how can I wire this up to avoid going up in ohm load and down in power output?
The amps I'm using are 1 ohm stable and are bridgable so 1 is master 1 is slave. I would normally just strap the amps and wire the subs up to 1 amp but then I'd need 2 4ohm subs or I'd have to run the amps at .5ohm and I don't wanna blow something or get different equipment.
B) Is it okay to keep both subs under this configuration in a ported box with one chamber, or since the amps are pushing 1 woofer at a time should I make the box have 2 chambers (effectively making 2 boxes so cancellation/different amp levels aren't an issue)? I can set each amp to be at the same level and I'd rather not have to mess with making 2 different ports and use more valuable box volume. with the design I want to use it's either 2 subs, equal distance apart share 1 full length port or I slap a divider between them and get 2 chambers and 2 half size ports from the same original port.
The subs, amps, signal, and power will all be the same so I'm hoping I don't have to worry about 1 woofer messing with the play-ability of the 2nd.
(P.S. this is my first thread here so I apologize if there's a better place for this or an answer out there somewhere, and thank you all in advance for the help! I truly appreciate it!)
Yes, just run each amp on each sub. If you set your gains the same, it's fine to run both subs in a common chamber with one port.
Run another fused power wire from the battery and ground each amp separately. Don't split your wire between the amps
So your're saying I should make 2 runs of power wire, 1 for each amp? Just for learning purposes, what harm does splitting 1 power wire do? I had thought to just run 0 guage to the dist block then 4 guage to each amp just to save on wire costs but the battery is under the back seat anyways so I don't mind running 2 wires. I've never used a dist block but saw others use them with multiple amps. Thanks! I won't bother making two chambers then //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
If the amps are designed to take 4 gauge wire, then that's fine to split the zero gauge into two 4 gauge wires. I didn't think you already had bigger wire ran to the back than the amp required.
Yes, I have the larger wire and I was just going to cut down the 4 guage I already have hooked up to the amp now. Sorry! So it looks like splitting the 0g power to 2 4g, grounding each amp separately, bridging the amps signal with an RCA, wiring each sub individually, and keeping them both in the same chamber (as long as I set the gains equally) will work out just fine. Takes a load of worry off man, I really appreciate it!! //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
Based off GM pickups of the same year (and that was GM), It SHOULD just be for the vehicle sounds that play through your stereo, such as the door...
You're the man. Give me your number so I can just call you the next time I have a question instead of having to make a post here. Lol. Thank you...
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
633
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
995
DrewB
DrewB
Indianapolis
adulbrich
maylar
    Jun 2, 2024
    Jun 1, 2024
