Wired my amp a few days ago ...now CAR WONT START
  • 6
just recently installed a 300w amp in my car. The car and music system worked great for 3 days until yesterday. The car wont start and my battery seems dead. this is a month old car battery.
my ignition switch is broken and wont release the key. the key gets jammed in the acc position. could my key be the problem?
Did you wire your amp remote to a continous 12v? So its been on for 3 days and you didnt realize?
As for the igniition thing what car is it? My 1990 c1500, AND 98 civic both had the same problem and it was the ignition lock cylinder had to replace it on both cars. $20 dollar part at autozone
nice its just a $20 part? im gonna have to look into that
I drive a 2002 mazda 626
remote wire is wired correctly the amp light is off when the deck is off. The car has been working fine for 3 days. this morning she wouldnt start.
lol i just looked it up and your isn't $20 its a lottle bit more... but could it be that your shift lever if automatic is stuck and it won't release the key? sometimes cars have a mechanism under the lever or shifter whatever you call it and the little mechanism to release the key when the car is in park gets stuck and the ignition stitch thinks the car is still in gear
It's stuck in accessory position and you're surprised the battery is drained?
^thisss???
It could definitely be the shift lever. Theres a little more movement than what seems to be necessary when I shift from P,R,D, etc
I see now how the key could drain my battery ...
does this mean my battery could be dead already? or does this mean it just needs a simple jump or charge?
---------- Post added at 12:27 PM ---------- Previous post was at 12:27 PM ----------
im pretty new to all of this ..ijs
Lol u guys will probably laugh at me.. But rookie mistake... When I reconnect the battery the nut on the positive terminal was stripped and the terminal was not on tight enough.. Bought a new nut and screw and fixed the issue... Now on to get my key out of my ignition
You know it's like 5 screws and a clip and my 3 year old could do it. Save your money do it yourself.. if you can change your battery u can change your ignition.. parts cheap too and comes with a new key. $25 dollars n 30 mins all it will take.gl
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
andriod detects sometimes iphone is connected i see it in the notifications but I'm guessing the app has a hard time knowing or its just a crap...
790
Jud6ementDay
Jud6ementDay
United States
Spl4200
    May 18, 2024
    May 18, 2024
