Wire gauge size help
Speaker Wire Gauge Chart
Ohms100w/10ft300w/30ft1kw/100ft3kw/300ft
0.5121084
11412106
216141210
418161412
820181614
Credit to Richard Clark for the chart: "to use the chart select the run length or wattage, whichever is greatest"
Edit: Found some more info he included with the chart:
"here is my recomendation for a no holds barred SPL or SQ system....bigger wire than this chart calls for will gain you nothing....... however for a non critical application it is ok to go one size smaller----- or two sizes smaller if it is a budget system............to use the chart select the run length or wattage----whichever is greatest-------
Watts/Length of wire
the values are rounded out to the nearest wire size.....if your amp wattage or wire length falls in between use the next larger size wire"
0.5121084
11412106
216141210
418161412
820181614
Dag nabbit, I guess I have to rethink using 8 gauge. According to this, I should use 6
29Shockwave
CarAudio.com Newbie
29Shockwave
Las vegas nv
Dafaseles
