Amp has power but subs suddenly do not have output
VolvoAcoustic
CarAudio.com Newbie
I've had this system for 15 years in 3 different cars. It has always worked.
One day a couple weeks ago I was driving and the subs turned off. I checked the HU, the RCA, I hooked the subs up to a receiver and they work, the amp has power and isn't in protect.
I ordered a new amp and the same issue.
The other day I turned the car on and the subs were working fine suddenly. I didn't change anything. The next day I went to test again and back to no subs.
The only thing I can think of is the amp is getting enough power to turn on but not enough power to push the subs? How would this happen suddenly and how can I test for that?
Could a bad ground be the cause? Nothing has changed ground wise. I don't understand.
Any ideas would be appreciated. Thanks
Fuse is fine yes.
Amp is Power Acoustik OV2-1200. Subs are 2 600w Super Blue.
I went out to check the sub make and realized one thing I hadn't tried is only having 1 sub hooked up. I unhooked the left and tried and wow, it's working. I then swapped the speakers and the other didn't work so I guess the one is blown then right?
So I hooked the one that worked back up and it doesn't work now either, even though it did just a few minutes earlier.
A sub can be blown and still read fine, ohm-wise. It's either that or too low of nominal ohm load on your amp. That's what I would look for.
See if when you push on your subs if you hear any rubbing. Look at the coils through the motor if you can, or the motor-basket gap, if there is one.
For anyone that finds this thread, it was an issue with the ground. Not sure why it suddenly stopped working but I cleaned up the paint and cleaned up the connections and it's working again
VolvoAcoustic
CarAudio.com Newbie
VolvoAcoustic
Canada
Buck
