will 3 15s fit in a 48inch box
NVM didn't come out right.
I did this once with 3 12s. You basically sink one down in and make sure you've left 80% of the cone area to fire through the area between the other 2 drivers.
/__\
Which 15s ?
The fi q neo, 15. Reviews are impecca, price is pretty good, and if i can fit them in a row, i think it would look pretty good. Im gonna make a shelf right above them, still below the window line, for my amps, probably 4 in all to include my front stage amp. One amp per sub, havnt decided on brand yet. Apparently i also have to wall off my civic for maximum output, most id be willing to do is wall off with glass or plexi glass for a "showroom" for the subs and amps. Plus my civic is not a beater that deserves to look like the majority of walled off crappy cars
I have 48" to work with as well. You might have to have a middle sub up a little more and the other two lower, if that makes any sense, to be able to fit those in that dimension.
all of this sounds very ghetto
if i don't do it right, yes it will be very ghetto, but i have high hopes for the car as a whole. I will be getting a paint job for it, solid white, then wrap with a white blue and black vinyl, white front, black rear, with some sort of blue design in to connect the two, lol money to burn i guess
i hope your wrong, if your right i will just go to 3 12's, but if I'm able and can make it clean i will just cut into the plastic, i would anticipate maybe an extra two inches total. i might be able to go up to a 50" box if i cut into the plastic
You should be able to. 15s are usually 15.5 OD, so that's 46.5... leaves you 1.5 inches of play.
I have 4 12s on a 49" baffle. Just brace it good and you will be fine. Make sure to brace the small area between subs really good.
You will be able to do it. They won't have any space between each sub box that doesn't matter. Port is on top or bottom along the length of the box. A proper box of 12 cu.ft with 15 sq.in of port area per cube comes to 180 sq.in so the minimum height of the box would be 19.5. You would have to play with depth and port tuning
DarkKnightSM
DarkKnightSM
Co Springs
YukonXL04
