will 3 15s fit in a 48inch box
NVM didn't come out right.
I did this once with 3 12s. You basically sink one down in and make sure you've left 80% of the cone area to fire through the area between the other 2 drivers.
/__\
Which 15s ?
The fi q neo, 15. Reviews are impecca, price is pretty good, and if i can fit them in a row, i think it would look pretty good. Im gonna make a shelf right above them, still below the window line, for my amps, probably 4 in all to include my front stage amp. One amp per sub, havnt decided on brand yet. Apparently i also have to wall off my civic for maximum output, most id be willing to do is wall off with glass or plexi glass for a "showroom" for the subs and amps. Plus my civic is not a beater that deserves to look like the majority of walled off crappy cars
Which 15s ?
Im thinking ill only have about 1/2 inch between each sub, even less. I WOULD be willing to cut out the plastic panels, or cut into them, to make room for the box, but id have to make it look super clean, no ghetto ****.
I have 48" to work with as well. You might have to have a middle sub up a little more and the other two lower, if that makes any sense, to be able to fit those in that dimension.
all of this sounds very ghetto
if i don't do it right, yes it will be very ghetto, but i have high hopes for the car as a whole. I will be getting a paint job for it, solid white, then wrap with a white blue and black vinyl, white front, black rear, with some sort of blue design in to connect the two, lol money to burn i guess
i hope your wrong, if your right i will just go to 3 12's, but if I'm able and can make it clean i will just cut into the plastic, i would anticipate maybe an extra two inches total. i might be able to go up to a 50" box if i cut into the plastic
You should be able to. 15s are usually 15.5 OD, so that's 46.5... leaves you 1.5 inches of play.
I have 4 12s on a 49" baffle. Just brace it good and you will be fine. Make sure to brace the small area between subs really good.
You will be able to do it. They won't have any space between each sub box that doesn't matter. Port is on top or bottom along the length of the box. A proper box of 12 cu.ft with 15 sq.in of port area per cube comes to 180 sq.in so the minimum height of the box would be 19.5. You would have to play with depth and port tuning
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
937
I don't know, maybe two 12's and two 15s on a IB wall maybe? Lol!
827
You may need to go to some shows and sound offs/meetings
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
DarkKnightSM
DarkKnightSM
Co Springs
YukonXL04
maylar
    Jun 2, 2024
    Jun 1, 2024
