Why won't my radio make sound?
  • 4
Benstump
I have an aftermarket radio and amp in my truck. Everything was working fine but I had to move my power cord that went to my amp. When I did it touched my truck. It sparked. It blew the fuse in the cord and I replaced it. Bit now my radio won't work. It come on and lights up but no sound comes out. If I plug and unplug the radio several times it will eventually come on but as soon as I turn the truck off and back on it it doesn't work again. What is the problem?
Check the fuse on the radio should be the issue //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif. If not then check all the wiring. If problem persists check cars electrical outputs to radio with dmm.
Well if the radio fuse was the issue the radio wouldn't turn on period, this is turning on but no audio.
What kind of radio is it? A lot of radio's have a protect mode that doesn't have any notification; i.e., Pioneers shut off their internal amplifiers and preouts if there is a short in any of the speaker outputs or RCA outputs.
Get a DMM and verify where the issue is coming from: either no voltage from the RCAs going into the amplifier, or no output from the amplifier (both are vAC and will increase and decrease with volume).
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
422
Not with a Toyota but with a Dodge Stratus. The Security Key Immobilizer Module (SKIM) was activated and it would not energize the coils. Check if...
Pull the head unit out, and at the harness use a test light to check 12v, ground, and Accessory. If all three are good, you have probably...
Not really, stock car speakers are extremely flimsy from the start and yours are almost 20 years old! I have no trouble believing the bloke who...
871
Benstump
Benstump
Byhalia,MS
robert420
audiobaun
    May 19, 2024
    May 19, 2024
