why can't you wire subs 1ohm
why can you wire 2- dual 4 ohm subs to 1ohm but 4 dual 4 ohm can't be 1ohm?
When you put two speakers or voice coils in parallel, you cut the ohm load in half basically. Two 4 ohm coils in parallel becomes a single two ohm load.
When you put two speakers or voice coils in series, you double the ohm load. Two 4 ohm coils in series becomes a single eight ohm load.
Let's look at your 2 examples. Two dvc 4 subs all in parallel:
Sub 1 Sub 2
4 4 4 4
2 2
1 --------------- 1 ohm load
Sub 1 Sub 2 Sub 3 Sub 4 (in parallel)
4 4 4 4 4 4 4 4
2 2 2 2
1 1
.5 ---------------------------- half ohm load
4 4 4 4 4 4 4 4
8 8 8 8
4 4
2 ---------------------------- 2 ohm load
You can play with the numbers and do the math, but the closest you'll get to 1 ohm with 4 dual 4 subs is either half ohm or 2 ohms.
Hope this helps. I do not have to work tomorrow and I've got Patron in my reach. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif:crap: **** so will my merlin MD2D run .05ohm? or will it be enough at 2ohm on 4 10in dvc4's type R's
I can't remeber without lookin it up but I thought parallel or series made it so that it cancelled the other vc out? so a dual 4 would stay a 4:crap:
well the only way to learn is first hand experience, get your subs wired up the way you think they need to be, and grab a dmm and check the ohm reading at the amp end and you will see that it isnt possible to cancel out the other coils.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
if its a decent amp and it doesnt want to run .5ohms, it should just go into protect mode. id try wiring it down to .5ohms and see if it works.
For all of you saying that it is Ohm's law, you are incorrect. Ohm's law relates voltage, current and resistance together, it does not however tell you how resistors combine. V=IR is Ohm's law, it states nothing about series or parallel resistances, just that voltage is a product of the current and resistance.
what if you were to wire it down to .5 ohms and add a .5 resistor in series before it goes back into the amp?
That resistor will use 1/2 of the power the amp generates. P=I^2 * R, so I through both is the same, R is the same meaning that 1/2 of the power will go to the subs, the other 1/2 to the resistor.
how hard is it to understand.
2 d4's all in parallel = 1 ohm
1 /2 =.5 1+1=2
NMBR1SPT
I Might Be Your Dad.....
NMBR1SPT
Orlando, Fla.
Redlineaudio
