why can't you wire subs 1ohm
Well, becuz Ohm's Law sez so. A dual 4 ohm subwoofer's coils can be wired in either series or parallel which results in either a 2 or 8 ohm load. It's just impossible to get 1 ohm total with 4 2's or 8's. Best you can get is either 2 ohms or .5 ohms. Of course you could always get dual 2 ohm VC subs and then that 1 ohm load is easy with four!!
yeah I know you can wire 2 dual 4 to 1ohm but if you cancel the second VC on the 4 dual 4's you are working with 4 svc right? I don't understand how it gets to .05 if you have 4 VC in the first set up and you cancel the 2nd VC in the second set you still have 4 vc to deal with??????
u cant wire only one vc on a sub and they dont cancel one another out
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
http://www.the12volt.com/caraudio/boxcalcs.asp
heres two diagrams how to figure them out
NMBR1SPT
I Might Be Your Dad.....
NMBR1SPT
Orlando, Fla.
Redlineaudio
