I'm officially addicted after hearing a 155db Yukon tonight.
My budget will be $10k max. Less would be better but I know it costs to get loud. This will be spent over the next serval months so I can have all of the equipment and start building in October/November
This will be going in a blow through in my 1998 Toyota T100.
The height of the bed limits my sub size. It is only 17" high so I can only do 10s or 12s unless I just do single top and bottom layer in the box, then I could fit 15s.
I have about 26 internal cubes before displacement if all outer walls are doubled. That would take up the entire bed so I would have to fit the batteries in the cab. If we don't use the entire bed I may put the batteries behind the box.
I would like to do either a 4th or 6th order. I will be doing interchangeable ports. One for the lows, one to be musical, and one for spl if this is all possible.
Will probably do dual Alts and 10 or more g31 batteries
If you were doing this, what subs and amps would you buy? I'll figure out the mids and highs later as well as the box design. Just interested in equipment recommendations.
After the box, Alts, batteries, wiring, etc. I would guess I will have around $5k left over.
Thanks for your input //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
