Which sub out of the 3
Yes i understand hispls the earthquake being 2ohm if it goes then my options ****. The synergy wfo 15.1 and twisted sounds twisted sounds ts1.8kw are underrated and can do 2000rms . I am really leaning towards two xfl12d4 . But trying private sale from member for 2 dd 12 redline in box if shipping is not crazy . Now with the old mind going i forgot if the redlines where dual 4. Yes i am the op and i do own the earthquake phd2 and hifonics 2200 brutus elite allready
This is a bit hard to follow, but does OP already own the two amps? I wouldn't buy either unless it was a really crazy deal. IIRC the old Earthquake was only 2 ohm stable so you really pigeonhole yourself for amp choices down the road when it fails from old age.
Also I believe Incriminator distributes in Canada, any of their products should be good quality and perform as advertized. If you're only looking to run 1200-1500W consider running 1 higher end woofer of a larger size over 2 smaller lower quality
Yes i own the earthquake phd2 and hifonics brutus elite2200.1
Whats your guys thoughts on the lanzar opti 1244d compared two the american bass xfl 12. Going to get a pair at 4ohm . And going with synergy or twisted sounds 2000 rms amp. I think they are very similar
No those lanzar subs are crap. Stick with the American bas xfl
I had an old d2, the black cased one. I loved that amp. Blew twice due to the speaker wire coming loose and shorting out. So dont count on the protection/fuses whatsoever. Lots of power tho.
I wonder why people are trying to sell you on a new amp then?
Really, avoid cheap subs please. Stick with the American Bass. The XFL is pretty solid.
Geting input from others stating both amps are not a good option. Like the hifonics will not have enough power in a round about way . The earthquake is getting older could break down . I also worried my self that the earthquake is very unclean to the point it will damadge subs .
Not sure about the hifonics, mostly they've been garbage since Gen X but it should be adequate, the Earthquake amps are getting a little old but they did dominate in DB Drag back in 02, keep them above rated minimum impedance and you should get good performance. Either way, unless you can get a good price for both and buy something nice I don't know why you wouldn't just use them as long as they last. Not sure what "unclean" means, but whatever. I'm guessing if your entire budget is 400$ and you don't have access to the USA marketplace you're not going to buy a better amp and sub(s).
rp69
rp69
calgary alberta
hispls
