Which "should" hit harder
either great minds think alike... or you're a COPYcat... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Loyd L.
great minds do think alike.... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
better extension from the two L5s? hows that? modeling in win isd (YES i know its not accurate but it gives a rough estimate) shows the single L7 having a TON of extension over the L5s....
this is why i was gonna go with an L7 over two L5 12s for my setup.. i would guess the SPL would lose a little but it seemed to me the L7 would have crazy low end.
help me out cause im debating between these subs too.
thanks for the input. I think im gonna get the 2 12", but does anyone have any specs on a box for them. Im buildin my own, but this boxs seems its gonna be more complicated.
also im gonna power them with a memphis 1000 watt amp
If I go sealed will it be worth the gain in sound quality.
And Bigbassman, for the box do i run it even with the top of the seat and run it striaght back, or do I follow that angle that goes up at like 45 degrees.
thanks
dont seal. if its SQL youre after then you might want to change your driver choices. my friend has 2 12 L5s ported and they sound good. bass still seems pretty tight and clear. (more so than i expected thats for sure). he has the same subs sealed for a while and they really didnt sound much better (except for the extension).
what freq are your porting to?
you're wasting your time with ISD, its a basic freebie lumping program that holds no value whatsoever for anything other than a crude port length calculator..
and yes... I've tested on a meter to prove ISD is worthless, and highly incorrect //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Loyd L.
TRANSAMCHARGER2
TRANSAMCHARGER2
CT
soundstreamer
