Which one should I get?
the best in these 4 choices
  • pioneer ts-swx2502
    Votes: 0 0.0%
  • Jbl ms-10sd4
    Votes: 0 0.0%
  • Total voters
E-10D2 - Sundown Audio 10" Dual 2-Ohm E Series Subwoofer E10D2:Amazon:Car Electronics This is a much better option for cheaper ore you can get the sd2 for 25 dollars more than the jbl.
Ok thanks, but the e-serie is not shallow enough, but the sd, i guess i could arrange something but I have two questions, will this amp be good enough for that sub? http://www.ebay.ca/itm/361117754735?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
And my second also important, what happened if the magnet touch the bottom of my box, I mean I have exactly 4 3/4" clearance, and the sub has a 4 3/4" depth? Thanks for your ansewrs
Ok thanks, but the e-serie is not shallow enough, but the sd, i guess i could arrange something but I have two questions, will this amp be good enough for that sub? Soundstream TA5 1250 CAR Audio 5 Channel Tarantula Series Power AMP Amplifier | eBay
yes the sd2's are made for that. Your going to want to put a gasket like weather stripping on the backside of the sub mounting ring it will give you another small amount of clearance.
REF1 500 Soundstream Mono AMP 1000 W MAX Subwoofers Speakers Bass Amplifier NEW 665644264630 | eBay
Rockford Fosgate P500 1BD Mono Amplifier AMP Class B D Punch SERIESP5001BD 0780687328429 | eBay
Rockford Fosgate R750 1D 750W RMS Mono CAR AMP With Bass Remote 780687333133 | eBay
Skar Audio LP 550 1D 550W RMS LP Class D Monoblock Single Channel CAR Amplifier | eBay
just a handful of amps I would pick over that one. don't let the ratings fool you that first soundstream you listed is overrated all these are gonna make rated power or be a little underrated. A couple of important questions are you planning on adding another sub later on and are you going to run your sub ported?
REF1 500 Soundstream Mono AMP 1000 W MAX Subwoofers Speakers Bass Amplifier NEW 665644264630 | eBayRockford Fosgate P500 1BD Mono Amplifier AMP Class B D Punch SERIESP5001BD 0780687328429 | eBay
I know I might not have got the best amp out there but all the ones you suggested are mono block and the one I have is a 5 channels. Maybe we should compare apples with apples
soundstream5ch
Qc, Canada
Jeffdachef
BP1Fanatic
BP1Fanatic
