Help choosing sub in my price range
ampageg2
Hi all. I'm currently looking for two 12" subwoofers. Budget around $200 give or take. I don't currently have an amplifier so I'm not worried about matching it up, though I'd probably prefer 4 Ohm. I've found the three below which look promising but I'm open to suggestions too. I'd like to keep suggestions to items that can be found on Amazon as I have a gift card. Thanks for the help!
Sundown E-12D4 V2 4Ω (Amazon)
Sundown E-12D2 2Ω (Amazon)
JL Audio 12W0V3-4 4Ω (Amazon)
Well your sub vc config depends on your amp or vice versa. Id suggest getting 2 D4 subs to give your amp a 1ohm load theres plenty of 1000@1ohm amps which is what youll be looking for if your budget is $200 for your subs. Most subs in that range are 500w
Heres another option
SoundQubed HDS212-D4 600W RMS:Amazon:Car Electronics
sundown E D4 is the winner here. Put it in a proper ported box and they will get loud in proper power, you can grab a 1000 watts rms @ 1ohm amp and they will be happy on it. You will need a proper ported box, do you have access to tools to build one?
Well I currently have a friend who owes me so I'm planning on recruiting him for the project. He had access to that. I had been running two RF subs in a sealed box but someone broke into my car and made off with my amp... so I figured I'd just start fresh.
I'd go with a ported box design if possible
here are some free designs *OFFICIAL* Free Ported Box Plans (56k NO!!) - Dodge SRT Forum
I'm going to attempt custom ported. I had a custom vented my first time and it got really loud but got way too hot. Been using the Rockford Fosgate setup ever since.
Btw I figured I'd ask here instead of starting a new thread. I found a Nakamichi and a Helix in my price range. What would you all recommend between these two amplifiers?
Okay great thanks! I'd read that Nakamichi was good but all of the threads I found were made around 2003 or before so I wasn't sure. Thanks again.
Ampage
ampageg2
ampageg2
Paris, KY
ampageg2
BP1Fanatic
BP1Fanatic
