Which One Should I Get ?
Damion50
I am putting 2 JL Audio 10W3v3-4 and was wondering what amp I should get to go along with it.. I am thinking of either 1 JL Audio Slash v2 500/1v2 or going with 2 JL Audio J2 250.1. The system is going to be in a 2005 Dodge Ram 1500 Quad Cab under the back seat..
Any help is and will be greatly appreciated.
Now that I think about it I do also have a MTX 600XD amp that was in my avenger powering 2 12 inch jackhammers.. I could also save some money and just use that amp if it would work..
well the 500/1 is 500watts and the j2 250's are 250watts so it is the same power output. The j2's are class a/b however so they will be much less efficient, as well as needing more power/ground wire and more rca's. Unless the J2s are much cheaper i would get the 500/1 (if those are the only options you are looking at). If you want a suggestion of other amps then let us know.
Damion50
Damion50
Toledo, OH
BrownVanMan
