which is better?
re is cheaper and more power...never any experience with re but id try it over the kicker
Honestly it's application dependent cus dePending on the box design, vehicle acoustics, and amplifier power both have there place. Power handling is not a power requirement and does not dictate how loud it would be. I would pick re mainly because they have better soft parts and the spiders aren't known to sag like the comp. I can make either sound just the same with the right combinations of variables.
You still think that mm4000 will put out 1800w but I'd put my entire setup up that it wouldn't clamp that at 13.8 or 14.4 for that matter. It's over rated and I know from clamping one the other day I got 1578 at 1.2ohm at 47hz my boxes lowest impedance rise and 14.4 not far from 1800 but still not 1800
I dont know whether to laugh or be confused so im both.
I said id try because i tried kicker. you just made it clear that my amp will do 1500 rms which is what im asking im not angry
id try re
9512 lol If you're in that realm of woofers, there's quite a good selection outside of those 2, but DD is a very good pick IMO.
2.5 cubic feet per subwoofer not total. Those X's require some room.
797
Is American Bass better then Mmatts? Again I'm in love with quality and smoothness with alot of power and so far I'm Does the ABs have better...
Alpine, and it's not even close. I own that Alpine unit and the 9-band parametric EQ is much more useful than the 5-band graphic on the...
xroshx
xroshx
Escondido, California, United States
lilboom
    May 24, 2024
