whats a cheaper but same quality sub that can go toe to toe with type r 12
ok we have a PROBLEM. i got every thing connected and nothing is playing, my amp turns on when my head unit turns on, but no subs are playing this iis how i wires my two subs
i used the inside speaker terminal wires for the end of the positive and negative where is says 4ohm
Rcas connected to input and not output? Check the amp if its on slave or master. Is subwoofer turned on at the head unit?
i check both input and outpur for rca cables, what should it be on master or slave? i never touched it, left how it was straight out the box not to sure which one its one and yes subwoffers are turned on at head unit turned them all the way up and nothing
Make sure its on master. Subsonic filter set low around 25hz on the amp. low pass at 80hz on the head unit. Check and make sure the speaker wire didnt fell out when you were mounting the subs to the box
I just CHECK aLl the wires even took the sub out the box to make sure nothing came apart and it still no go what is going on, made sure the power cable was secured tight, rca cables were in the right place, amp is on master, and the rest of the settings i never touches like the gain and stuff, amp turns on my nothing help me pleaseeeeee
bro, text me. Do you have a multi-meter? You can test to see if anything is comming out of the speaker inputs.
Also if you have Aux to RCA y splitters and plug your phone into the amp rcas, you can test to see if there's something wrong in the signal line.
What head unit do you have?
i have alphine 151 Alpine
i hav a aux cord but not one with a rca splitter
i dont have a multi meter
ygbodybuilder10
ygbodybuilder10
United States
Jeffdachef
