It means you havent even pushed them, crank it up a tad more. Get a voltmeter and see your drops to see if you need to do the big 3 upgrade. Your amp kit does not leave enough for the big 3 upgrade so dont tripplus i been checking my subs and amp and no heat or even a little warmth is getting to them, i think i play them pretty good, whats going on with that
when u say crank it up do u mean the volume button or the amp settingsIt means you havent even pushed them, crank it up a tad more. Get a voltmeter and see your drops to see if you need to do the big 3 upgrade. Your amp kit does not leave enough for the big 3 upgrade so dont trip
Your head unit should have a subwoofer level adjustment. You can use that adjustment or amplifier gains or head unit volumewhen u say crank it up do u mean the volume button or the amp settings
you can use any gauge wire.hey people my remote wire ripped last night and i was wondering if it would be ok to connected it to a 12 gauge wire to add length
the remote wire appears to be 18 gauge
but want i want to do is use the 18 gauge wire i have left that hasnt been ripped and just connect that with some left over 12 gauge wire, that wont cause any problems?you can use any gauge wire.
there's no issue. Wire is wire.but want i want to do is use the 18 gauge wire i have left that hasnt been ripped and just connect that with some left over 12 gauge wire, that wont cause any problems?
im on to u buddyUse some 4/0 wire //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
go to your local o reilly's advanced auto or autozone and have them test your alt and battery. Your batt could have been drained a bit and just need to be charged or worst case scenario, alt or battery failure.hey people, so i turn my gain up a little bit last night and 5-10 mins later my engine light came on, now it could be just a coincidence but if its not is this normal,damm light wont go off after i turned amp off
i have a crown vic 2003
