What would you set the HPF and slope on these?
  • 4
What it's rated, ie published requency response figure, does not = what it plays well at. The configuration of your system, positioning, and the amount of power applied to the driver come into play .
Sorry about that.
Basically what I am trying to do is to take JL Audio VR-650csi components, removing the included passive x-over and go active off of the Alpine CDA-9887 3-way feature. I'm doing this mainly because the tweeters are in the A-pillars and the drivers are in the lower part of my doors and the imagining ***** this way. I can't make any major changes to the car so I have to keep the speakers where they are.
I will be driving them off of a JL Audio 300/4 amp which is rated for 75x4.
Here are the specs of the specific JL Audio VR series Tweeter (VR075-CT) in question.
Continuous Power Handling: 50 Watts (with appropriate crossover)
Peak Music Power: 125 Watts (with appropriate crossover)
Rec. Power Range (per channel): 2 - 50 Watts
System Efficiency: 89 dB @ 1W/1m
95 dB @ 1W/0.5m
System Nominal Impedance: 4 ohms
System Frequency Response: 4 KHz - 25 KHz ±3 dB
OK now can you articulate exactly how going active will cure the problems caused by your speaker placement? Maybe I'm a tard but I don't exactly understand your goals.
545
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
896
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
944
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
  • Locked
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
phish368
phish368
Long Island, NY
phish368
    Jun 15, 2024
    Jun 15, 2024
