Set Screw Replacement Size Speaker - JD1000/1
zoltman1991
CarAudio.com Regular
Help! I tried JL's site and a few reddit posts and what not.
What is the exact replacement size for the set screw of the speaker terminal for JD1000/1.
I found M4x9mm in one post, but this was for their Slash series. Not entire sure. Amp is not with me at this moment and I'm trying to order online.
-PS - it's an amp I sold and I just realized one of the terminal screws was missing.
Take out another set screw and go to Lowes, Home Depot, etc. They should have a tool there helps you figure out what you've got.
Yaaa definitely plan to. I'm stuck at work for 12 hours. Was going to see if I can get someone to get it for me, but I just don't know the exact size. Might just have to wait until tomorrow when I can actually take it to the shop. But they should definitely have all sizes right?
Maybe the shop will have it, but it will probably be expensive unless they can grab one off a dead amp. In my area Ace Hardware tends to have the best selection of these odds and ends type of hardware. Ideally you want the screw to be the same material as the terminal. Good luck.
zoltman1991
zoltman1991
houston
Jimi77
