What subwoofers for the rockford fosgate t1500-1bdcp
wow thank you, where at in WA do you live, I'm in Oregon and id pay you to make the box lol. but my max dimensions are a box of 46*23*26. getting a gross volume of 15.91 cubic ft with those dimensions and my subs call for roughly 5.5-6 cubic feet net per sub. here is what i was thinking but i would appreciate a sketchup from you if you got time.
I actually would stay around 5.5-6 cubes. so if you use 26 height, you'll want a 12 inch sonotube thats around 19-20 inches long.
If you want a less tall box you can go down to 24.5 and use a 10 inch sonotube at 12.5 length.
both options will keep you around 5.5 net per sub.
so for your first diagram, since i would be sliding this box in long ways, the port would be firing to the side of the car, is that acceptable? and also do you know how long each port extends into the box or were you just sketching up the look. either way thank you for the help.
If the port is on the sid of the box, do you have any clearence between that side panel and in your car?
it will be up against one side and if the port is in the position of ur first diagram then it will be firing towards the opposite side kinda like this.
Huh? No....if you plan subs up, port to the side, then the port would be facing your back fender cover.
no if i have to slide the box in long ways, not the traditional way, then the subs would be firing up but the port would be firing to the side of the car. here look at this picture, imagine this tool box as my subwoofer box, it will be slid in long ways and subs would be up and port firing into cabin towards opposite side.
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
368
Lighten up man, it's all in good fun. Having more to go on than I want a sub that is less than 6" deep heps the forum narrow the focus. Why...
Adire Brahmas were incredible subs. One of the first subs that could really compete with the JL w7s. Super flat BL curve gave the subs a really...
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
cparker2591
albany, OR
cparker2591
    May 31, 2024
    May 24, 2024
