crakerhead 10+ year member CarAudio.com Elite 681 0 Richmond, VA Apr 23, 2003 #1 what size anl fuse should i use for jbl 1200 for short periods of time? itd be used only for shows and what not. it's my secondary one. thx! Click to read more...
Gauntlet 5,000+ posts bulletproof 8,336 0 Cleveland, Ohio Apr 23, 2003 #2 Is it running at 1 or 2 ohms?
OP crakerhead 10+ year member CarAudio.com Elite 681 0 Richmond, VA Apr 23, 2003 Thread Starter #3 2 ohms, should 100amp be ok being it won't be on for long?
OP crakerhead 10+ year member CarAudio.com Elite 681 0 Richmond, VA Apr 23, 2003 Thread Starter #5 thx!
D danfortner 10+ year member Senior VIP Member 182 0 Mystic, CT Apr 24, 2003 #6 I think you may have made up your mind on this one, but a lazy method of figuring out what fuse you need is divide the wattage RMS by 10, and you can go a little below and a little above that. http://www.eatel.net/~amptech/elecdisc/fuses.htm or you can go there and use the system design assistant to come up with the optimal fuse ratings, wire gauges, ect
