What should I look for when i buy subwoofers???
  • 5
Mono blocks don't have 2ch. Maybe you meant bridged at 4ohms. Just pick out a sub that works with the min ohm that your amp can run
You have SSL now might as well bite the bullet and get some SSL subs rated at 1000 watts both it should match your amp
If you haven't got the amp yet do some research and stay far away from ssl
you will be splitting the power so u need 500w subs. at what ever load the amp does 1000w at. make sure is in your budget and the correct ohm load for the amp
Have you check to see if the prefab would fit...
13
The CT's are nice, That Sundown is a a frik'n beast!
956
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
778
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
913
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
weedy
weedy
Naples, FL
wone
Decebal
    Jun 10, 2024
