weedy Junior Member 21 0 Naples, FL Apr 10, 2013 #1 If im looking to buy 2 15" subwoofers to run a SSL 1000w 2ch monoblock to what specs and type subs should i look for?? Click to read more...
AnthonyO 10+ year member Budget Banger Connoisseur 3,948 754 Minot, North Dakota, United States Apr 10, 2013 #2 Not sure if troll or serious.....
OP weedy Junior Member 21 0 Naples, FL Apr 10, 2013 Thread Starter #3 seriously... would DVC or SVC be better, what 15" models are recommended for a 1000w amp
J jar1zx 10+ year member CarAudio.com Elite 586 2 Nashville Arkansas Apr 10, 2013 #4 Mono blocks don't have 2ch. Maybe you meant bridged at 4ohms. Just pick out a sub that works with the min ohm that your amp can run You have SSL now might as well bite the bullet and get some SSL subs rated at 1000 watts both it should match your amp If you haven't got the amp yet do some research and stay far away from ssl
juanmgarza26 10+ year member CarAudio.com Elite 568 0 McAllen, TX Apr 10, 2013 #5 you poor child... may the lord help you
wone 10+ year member CarAudio.com Veteran 2,362 8 ...? Apr 11, 2013 #6 you will be splitting the power so u need 500w subs. at what ever load the amp does 1000w at. make sure is in your budget and the correct ohm load for the amp
