what should I do with my truck?
did you crawl under the truck and have a look for your self ?
if your engine is BURNING the oil - then yes its done.
but if its just leaking
it could be from a fiew problem areas - like the front and rear main seal would be terrible
did you crawl under there with a wrench and try and tighten up all the bolts holding on the oil pan and **** ?
check around for other areas leaking out oil... maby its something stupid like a oil preassure sensor that is leaking like a std
or maby the motor is done... investigate
I had a mechanic and a person to look at it. Both of them said the bottom end was toast. Dunno how much it would cost to redo the whole bottom end. Doesn't burn oil.
Hmmm. A leak does not signify the bottom end being "toast" at all. A leak is a leak. If you threw a rod through the pan and it was leaking that would be a different story. Get under there and see where it is leaking from. Most likely the rear main. You can just keep re adding oil....
the oil drips right onto the front cross member. like not on the back of the engine in the middle. And you hear it knock when running. Sounds like it's gonna blow up if you give it some gas.
u can easily find an engine, harness and *****, say an ls1 and replace it all.
usually junk yards have good deals, and craigslist has even better ones if u can find them.
Juice0723
Juice0723
Canada
Ignatowski
